Anyone have something rigged up to pre heat/defrost their MR?
rev3gtturbo
Re: Anyone have something rigged up to pre heat/defrost their MR?
Post by rev3gtturbo »
For me the hardest bit to defrost is the windscreen washer jets as the fluid gets no heat from the engine like most cars.
This year I am using some screen wash thats not supposed to freeze until about -23. If that doesnt work then it will need a hot water bottle.
ryan
Post by ryan »
I had a remote start alarm, so the car was always warm by the time I got to it :)
jasongtr
Post by jasongtr »
ryan wrote:I had a remote start alarm, so the car was always warm by the time I got to it :)
the op wont want to gdo that due to his exhaust and the time he leaves
ryan
Post by ryan »
Ahh, forgot he mentioned that. Could always go for a less ASBO exhaust :lol:
N9THX
Post by N9THX »
I'm going to put the original one back on for the sake of my hearing as soon as we get some decent weather :thumleft:
carlos9999
Post by carlos9999 »
i always use the air/con in the winter.... that gets rid off moisture.. :thumleft:
Pidge
Post by Pidge »
Steve Horrocks wrote:New shape golfs come wih anoption to have a plug on the front of thwe car to plug it in a night to get engine up to temp (ish) ready for a cold morning set off.
Sounds like a Golf :lol: :roll:
StevieL
Post by StevieL »
I'm thinking about maybe getting a washer bottle & pump from a Land Rover, relocating it to the engine bay (near the turbo/exhaust but not close enough to melt it), and running some hose to the bonnet through the inside of the car to keep it warm during winter months. :-k
Pidge
Post by Pidge »
StevieL wrote:I'm thinking about maybe getting a washer bottle & pump from a Land Rover, relocating it to the engine bay (near the turbo/exhaust but not close enough to melt it), and running some hose to the bonnet through the inside of the car to keep it warm during winter months. :-k
You still have the same problem though don't you as it has to go out side at some point.
StevieL
Post by StevieL »
If I run it through the inside of the car, under the centre console or carpet or something, then into the frunk via the hole behind the brake pedal, minimizing the time it spends outside, I reckon it would work :thumleft:
*Edit*
I think the main problem with the MR2 system, is the washer fluid bottle is infront of the NSF wheel, where it get's all the freezing cold air on it. :-k
Pidge
Post by Pidge »
I would do as you said steve but put some sort or hose over it to form a little insulation that should help a bit.
Also try not to use the water before your about to stop then this would stop the nozzles freezing up.
StevieL
Post by StevieL »
I got a washer pump, some hose, and a heated windscreen washer jet from a Vauxhall Omega.
So I'm going to wire a switch to the pump, have it in the cab attached to a small bottle of washer fluid, with the washer jet fitted to my windscreen cowling directed at the drivers side.
This is only if I get in the shizzle again this year :pray:
Tiamat
Post by Tiamat »
StevieL wrote:I got a washer pump, some hose, and a heated windscreen washer jet from a Vauxhall Omega.
A slight resurrection of the thread, but was going to say to people, I was out in the Celica today (ST182) and the washer and pump etc for the rear wiper on the lift back is all in the front, so if you want a pure toyota conversion then you can always fit a Celica one and know that it will do the business with the pressure.
Brylt
Post by Brylt »
There used to be cooling system heaters available in classis car mags, they work by fitting a heater/pump unit in the cooling pipes and simply plug in to the mains when the car's not in use, when you come to use the car the engine allready has warm water in the cooling system so you have warm air straight from the blowers and the auto choke is off so it saves on petrol.
I'll try and find a link to put up.
Bryan
asdrewq
Post by asdrewq »
To defrost the car the other morning I balanced a 1600w hairdryer on the rear cubby box pointing forward, combined with an extension lead. Worked a treat.
I think a heater of any less wattage than that would take too long to do any good in this weather.
The ultimate option would be a petrol/diesel fueled Webasto 5kw engine coolant pre-heater on timer or remote!
