This has been an on going problem for the past year, my Speedo is electronic and seems to do a lot of dancing around at first start idle, always happens in the morning, I go to start her up and the Speedo will shoot up to 60mph and drop down slowly but wont normalise until I start moving the only time it will normalize is if I put it into reverse but soon as I take it out of reverse it begins to rise when I havent started moving yet, but while driving its wobbling like a trooper and irons its self out after about a mile or so, its fine when driving and when the engines hot and idling the needle is fine, what I have noticed is that when the car is idling if I put the alternator under a bit of strain like put the head lights on or put the heater blowers on full blast the battery needle drops a bit and the Speedo needle raises to about 20 mph for a couple seconds then the battery needle rises back to normal then the speedo need returns to zero again.
Ive run some tests on the battery and alternator as I got my suspicions that it might be a lazy voltage regulator with in the alternator but i might be way off
The battery is about 4-5 years old holds a decent enough charge and starts the engine fine, it reads 13.89 volts just after I have taken the car out and 11.83 volts when left for a day or so, while cars running at idle the alternator is pushing out 14.49 volts and under strain with all lights on, wipers going and all indicators on and heater blowers on the alternator is struggling and only pushed out 12.78 volts at idle and dont get much better with revs.
Any help would be appreciated, I have been told that a rev limiter might be fitted but looked behind the clocks and no such thing exists all connections seem to be fine
