Well you get the idea
Gee Man wrote:greeny wrote:Where did you crack it lad?
In all honesty, id go late 5s block now and not worry about it again.
Not 2 sure yet mate as the engine is still in the car.But it over heats once you pull up after giving it a boot full or on a longish motorway drive.
I was on a stock rev3 head.
I thought 1.5 bar was ok and anything 1.6+ was the problem.It's luck of the draw I guess as people on here have run 2 bar
+ and never cracked.
Kongaroo wrote:Sorry to hear about your car Dan.Can't see you going back to standard though after pushing 400+BHP
mr2nut123 wrote:Ahhhh, come off it JJ.![]()
400bhp MR2s are addictive.
The more power the better
Steve Horrocks wrote:As Chris, im on stock block(at 86.25 with forgies) stock had
& cams and running 1.9bar.
It's been built for a while now
& totally fine.
(and for sale, hint hint!)
JJ wrote:Good advise there..
Just to elaborate on countering sleeve movement,'top hat' design requires both machining the full bore and a wider section which interlocks the liner to the block
! Liners not going to move either direction in this case once the heads bolted down.
Straight liner approach..
.well shoot the engineering approach on that one
gazrev1tubby wrote:Can I ask what your symptoms were that led you to believe the block had cracked, also how did you diagnose it?
