Immobiliser issues
MarkR32
Immobiliser issues
Post by MarkR32 »
Right think i have tracked down my probklems to a standard Toyota immobiliser..
Does anyone know how to disable this or is there a reset proceedure i can do
Mark
spoofer
Re: Immobiliser issues
Post by spoofer »
I have simler fault,
turn the key can hear the relys in theengine bay click, but teh start motor doesnt turn. ](*,)
I know where alarm is but not how to bypass it.
had a clifford fitted to my last mr2, and the tech un plugged teh factory unit and grounded one of the pins. but not sure with pin it was :(
MarkR32
Post by MarkR32 »
i resolved this, turned out not to be an immobiliser issue at all, i must have upset on earth wire at some point whilst stripped the car down, so after much searching i contacted Paul woods @ Woodsport and he talked me through earthing the starter realy and hy presto my car works again
let me know if you ned any help
mike1984uk
Post by mike1984uk »
this seems to be a common problem popping up. i suffered the same trouble, was determined it had to be alarm fault (got a toad alarm)
bit of investigating and found the starter relay had lost its earth, spliced in a wire and put it straight to the starter relay bracket and sorted.
markr32 - can u bump start the car when the alarm is disarmed?
MarkR32
Post by MarkR32 »
i have earthed my starter relay now so it starts on the turn of the key, not sure what caused it, as i have been over the car again and there are NO loose wires but hey ho .. starts now so not too fussed haha
i just cut the black/white thin wire added a terminal block and a think earth wire and attached this to the boot wall .. starts perfectely .. (when the battery has charge haha) #-o
