ashman wrote:greeny wrote:
If so make sure you get the exhaust manifold!![]()
+1
Absolute bargain that
It is indeed! I was tempted to try and find the cash for it, even though ive no use for it
+1
Mr2_BadBoi wrote:.
.but then mapping going to use ryan,or 2bar tuning not sure and recommendations??
Mr2_BadBoi wrote:Hey buddy that's some high hp your after, what mods do you have at the moment and what rev is your engine? I'm pritty sure if your running a rev3 you should be fine have hurd the rev2 inlet mani's are more restrictive, most peaple with rev2 opt for the rmr manifolds there highly rated and from what I have seen and read very well made etc, as for the inlet manifold you posted I wouldnt fit one if I was given one, I have seen one of theses before the build quality is very very poor and wasn't even flat and had to be skimmed as for the TB that just fell apart after a few weeks, if your running a rev3 inlet manifold just keep it buddy and fit an oversized TB most fit 90mm to 95+mm hope this helps
Hi there i am buying the engine out of the phoneix ex demo car,and the manifold end of this month
i do have a gt3076r but am thinking of a gt35 as that can handle more power,and sard 850cc injectors,sard fuel rail,uprated fuel pump,boot mount intercooler,but i want a inlet as i want the best for my car and not a cheap rubbish crap,ecu side am going to go solaris if that is what it is called lol
i have got lots of bits which i bought for my own build which am going to get rid of
will place an add in for sale section soon
hks 272 cams and hks pulleys
hks f-con ecu with gcc controller all for mr2
hks mushroom filter the whole kit(proper hks)
Chris wrote:That twin scroll is well tasty! Be needing 1200's ish injectors though min.My 1000cc's were running 120% duty at 4 bar base fuel pressure for 635bhp.
Mr2_BadBoi wrote:its funny this because i seen the mr2 in the banzai magazine and my head came full of ideas,ur a big insperition chris lol
