I'm getting very little if no boost at all from my ct20, I'm also getting a rattling noise when the very little boost does come in.
What I've checked so far:
examined the turbo from both side it spins freely and has no play above normal, both compressor and turbine wheels have all the blades.
none of the pipes are leaking air
the dump valve is working
all the cylinders are firing and have good pressure.
Does any one know what the affects would be if the actuator died?
Iain
