This seems to be an intermittant problem.
ive tried the following:
coil ok
power to coil ok
igniter ok
HT leads ok
spark plugs ok
IGT igniter signal ok
fuses and relay ok
I really dont know what else to check
alan wheeldon wrote:I have not tried the relay earth.The ignitor frame is rust free and has a good earth.
I noticed last night that I cant check for error codes now.There is no management light on the dash anymore.
I checked the bulb and that is fine.
Could this be related or yet another problem?
Blue_5 wrote:This sounds very similar to a problem i had on my old tubby- the management light would not come on and the car would not start.
It faded in after around 10 seconds but the car still would not start.
It would finally start, seemingly when it wanted to.
My ECU fuse also kept popping, which said to me i had a short somewhere.
Have you checked power to the ECU?
