The engine has completed around 110000 miles, mixture of miles and kilometers as per usual.
Mucho thankings
John.
black gts wrote:i have a rev3 turbo and when i got it it had 150ish on 1,2,4 piston 135psi on number 3
i got some forte injector cleaner and put a full bottle in a quarter tank of fuel and give it a blast.
this was done on instruction of an engine builder, the next compression test i got 170ish psi across all of the cylinders
forte chemicals are what vw main dealers use
hth
paul
jimGTS wrote:I don't remove any fuses.
Just unplug the coil lead.
