For a rev3 turbo:
Water pump is 16110-79135
Oil pump is 15100-88460
Oil pump crankshaft seal is 90311-42026
Oil pump pulley
(if required) is 13524-88460
Oil pump gasket is 15197-88460
Water pump comes with required seals, gaskets and o-rings as well as a pulley.
Oil pump doesn't which is why I've listed them.
You'll almost certainly be able to reuse the pulley from your old pump but if not there's the part number there too.
There are a few different gasket sets, what are you after exactly?
