Just sorting out my Mk1b to get through long overdue MOT and the indicators are playing up.
Is this the most likely culprit, and if so, is there a knack to getting to the relay
Thanks!
Dave
Tiamat wrote:From what I can see from the Haynes manual, not checked BGB yet, that you don't need to remove the dash to get at anything.![]()
The flasher unit is just inside the driver;s door
- check connections
(Page 212 of the Manual states how) or you have the connector at the base of the steering column.
No need to remove the dashboard though might have to remove the seat.
cartledge_uk wrote:nope, its in the front boot if I have the right one.
midlife crisis wrote:Jimi,
So to confirm, I need to get behind the dash to change the flasher unit?
Thanks again![]()
Dave
