What is this sensor???
tarmac terrorist
Re: What is this sensor???
Post by tarmac terrorist »
DavesMr2turbo wrote:
tarmac terrorist wrote:looks like the cold start injector timer switch sensor they are common for breaking away like that, i dont use one now as ive converted to rev 3 ecu & wiring :thumleft:
I went to toyota and they think its a cold start injector timer switch. bloody £100. Also ordered a ECU COOLANT temp sensor at £50
You sure they got the correct price lol:)
The Cold start injector timer switch is what toyota called it. is that same as u guys sed for Cold start switch sensor
cheers
i work for toyota as a tech & yep thats the right name for it :thumleft: the price sounds about right they used to be way more than that :(
toxo
Post by toxo »
Last water temp sensor I got from Toyota was £38 (they are £15 from camskill) but I get a discount on some parts.
tarmac terrorist
toxo wrote:Last water temp sensor I got from Toyota was £38 (they are £15 from camskill) but I get a discount on some parts.
was that the one for the gauge tho :-k
toxo
Post by toxo »
No, ECU
Its 89422-35010 retails at £39.91 + vat
tarmac terrorist
toxo wrote:No, ECU
cool :thumleft:
havent checked these prices on the epc at work for a long time,i know the cold start injector timer was always the expensive one :(
tarmac terrorist
DavesMr2turbo found this on the net should help you in the future :thumleft:
toxo
Post by toxo »
toxo wrote:No, ECU
cool :thumleft:
Ah well, I don't need to worry about that one :D
tarmac terrorist
toxo wrote:No, ECU
cool :thumleft:
lol na me neither as ive converted mine to rev 3 wiring & ecu :D :D
DavesMr2turbo
Post by DavesMr2turbo »
cheers lads for all your help. i think its expensive but i need the sensors. sopose once i got them least i know there brand new.
good old ecu reset aswell. best way to do ecu reset is to disconnect batt???
toxo
Post by toxo »
Yeah that's my philosophy! Plus if it's giving you gyp it's obviously sensitive and significant to the running of the car so why not replace like for like?
ECU reset should ideally be done by removing EFI fuse in the engine bay and ECU-B (I think? maybe EGU-IG?) fuse in the frunk. It's easier to remove the -ve from the battery for a few minutes but that will reset your stereo etc.
DavesMr2turbo
yea replaceing both sensors and thermostat. are the thermostats easily ton change?
