What is this sensor???
DavesMr2turbo
Post by DavesMr2turbo »
Hi all
I am changing over my blown CT26 to a CT20b turbo.
On Connecting the water return pipes i noticed that the white sensor below is loose. the nuts is well tight in there but the white plug bit can pull in and out and its pretty loose.
http://img191.imageshack.us/i/sdc126291.jpg/]Image
Could i just push the sensor back in or will it leak coolant? Also what sensor is it??
This is bit of my blown turbo not only the manifold blowing so was the turbo to the manifold and blowing at the downpipe lol. show u the tubby pic lol :lol:
http://img25.imageshack.us/i/sdc12601.jpg/]Image
tarmac terrorist
Re: What is this sensor???
Post by tarmac terrorist »
looks like the cold start injector timer switch sensor they are common for breaking away like that, i dont use one now as ive converted to rev 3 ecu & wiring :thumleft:
Razor04
Post by Razor04 »
Thought it was the oil pressure switch? or is that higher up?
tarmac terrorist
Razor04 wrote:Thought it was the oil pressure switch? or is that higher up?
oil pressure is the large one at the top :thumleft:
DavesMr2turbo
so what is it and well it leak lol :lol:
let me know.
DeusMR2
Post by DeusMR2 »
Nothing will leak but it will be harder to start from cold. Mine has broken and I need to to turn the engine over twice to get it to start in the morning.
Easy (and cheap) way to connect one of the wires to a switch that toggles between 40k and 80k Ohms. Switch it to 40k when cold and 80k when warm. The other wire goes to ground (I think - I haven't tried this out yet!)
Bit of a hassle I know but I couldn't find a second hand switch anywhere!
DavesMr2turbo
anyone else???
DavesMr2turbo
need to order that sensor from toyota tomorrow. can anyone tell me what it is asap. the one above the red square is that the ECU Temp sensor??
need some help guys
cheers
toxo
Post by toxo »
The sensor in the red box is the cold start switch and if the top is loose then it's fecked and you need a new one. It will be rotten inside, like this:
You can't 'push it back in' because it's not a push in sensor, it's a screw in one. If the plastic bit's loose the internals aren't attached properly anymore.
The sensor to the right of the red box is the ECU temp sender, it has a yellow plastic connector.
The sensor above the red box (large round one, single spade connector on it) is the oil pressure switch.
Edited cause I got it wrong :oops:
DavesMr2turbo
good mine. that the sensor i can pull in and out lol:)
proper loose. will that affect car driving once car is warm???
i got ecu temp sensor on order from toyota. to replace it will i loose coolant.?
cheers
dave
toxo
Post by toxo »
Actually I might have that wrong - mine's a rev3... 2 secs and I'll double check.
DavesMr2turbo
cheers buddy. it meant to be solid and i can pull it in and out. what ever sensor it is its fecked. hope it is the ecu coolant temp sensor as i ordered one from toyota :)
let me know asap dude:)
cheers
dave
toxo
Post by toxo »
Yeah I did have it the wrong way round, whoops!! Sorry about that. Edited now to correct.
You will lose a tiny bit of coolant when you swap the ECU temp sender but not very much and the next time you run the car to warm it will bleed out to the cap so you can just top it up once its cold
DavesMr2turbo
in the box is a COLD START switch then. that is fecked then. what problems should that give me.
gonna change the ecu coolant temp anyway.
let me know the problems i should get with the cold start switch broken??
cheers
tarmac terrorist
DavesMr2turbo wrote:in the box is a COLD START switch then. that is fecked then. what problems should that give me.
cheers
the ecu will not be able to work out engine temp so wont know what fueling to add for cold start ,possible rough idle from cold for couple of minutes & maybe a little difficult to start ie take a few cranks
DavesMr2turbo
what about when full warm???
anyone else think of anythink
cheers
dave
tarmac terrorist
DavesMr2turbo wrote:what about when full warm???
cheers
dave
shouldnt be any probs when warm as it is only for cold start :thumleft:
DavesMr2turbo
well weekend i am replacing ecu coolant temp sensor and cold start switch and therostat with full coolant change and bleed system.
next on my list is set ht leads with dizzy cap and rotor arm and fuel filter/
ecu reset to
sound right move
cheers
DavesMr2turbo
tarmac terrorist wrote:looks like the cold start injector timer switch sensor they are common for breaking away like that, i dont use one now as ive converted to rev 3 ecu & wiring :thumleft:
I went to toyota and they think its a cold start injector timer switch. bloody £100. Also ordered a ECU COOLANT temp sensor at £50
You sure they got the correct price lol:)
The Cold start injector timer switch is what toyota called it. is that same as u guys sed for Cold start switch sensor
cheers
DavesMr2turbo
sound about right guys
