[Mk2] [NA] Snow = bump
willmr285
Post by willmr285 »
Hi all, Driving to work yesterday in our lovely weather conditions, going about 10 mph around a corner, rear end slides and hits a curb, the wheel now looks like it is on a slant and anything over 25mph makes the whole car shake.
Would it be the rear axle? or wishbones i do not know much about cars from a mechinacal side. urgent help needed
Steve-O 2007
Re: [Mk2] [NA] Snow = bump
Post by Steve-O 2007 »
could be your wheel. Take your wheel off and ask at a garage / tyre garage if they could put it on the balancing machine to check
HighwayStar
Post by HighwayStar »
Check the wheel is still held on properly by all studs securely.... it could just be loose with some nuts pulled over the threads. Next I'd suspect something like one of the suspension arms (perhaps it's been bent) and this is more likely so get it to a good garage for a look over.
R
SFLee
Post by SFLee »
or take some picture of the rear wheel
Raf
Post by Raf »
best take a pic of underneath if you can so we can see suspension components.... i doubt the wheel is that bent to give that +camber effect?
can adjust crash bolts but best checking no suspension comps are bent (track rods, wishbone, droplinks etc)....
C50
Post by C50 »
wheel must be unbalanced to make the car shake, try jacking the rear up and spinning the wheels to see if it's buckled.
must have deffo bent suspension for the camber
