The engine has an apexi intake, apexi exhaust, decat, greddy rep intercooler and mbc
greeny wrote:Your too lean early in the power range, coming on boost your@ 16-1!
Whats your setup chap?
easty-5 wrote:Running lean gives more power.
When are you coming on full boost? Your AFR curve is pretty even.It looks to be running a bit lean between 3000 rpm and 4500rpm when it starts to richen out.
Dundee wrote:greeny wrote:Your too lean early in the power range, coming on boost your@ 16-1!
I know, why so lean on tick over? the computer was reading 20:1 at times.Setup is standard rev3 turbo fueling and ecu bar the uprated pump,
jdbecks wrote:why did you change the pump?
greeny wrote:Dundee wrote:greeny wrote:Your too lean early in the power range, coming on boost your@ 16-1!
Idle should be around 14.5-1 IIRC.
Where did you have the runs done?
Are you sure there wideband was working correctly/calibrated.
The standard ecu should be keeping you alot richer earlier, yet its dropping into the 10's higher up.
Whats the uprated pump? What boost were you running?
