Just to let everyone know that my MR2 is the sunroof version, and the T-Bars have an extra strengthening panel inside the sill.
Hello everyone, just been looking at the sill's at the rear of me 2,
(she failed her MOT last month on these areas) and after a closer look found that the inner sill have also corroded to a degree of me being able to put my finger through it with little pressure.
To say I was gutted would be a big understatement, getting a bit depressed about her know! as she's had a lot of work and parts sorted on her, here's a list:
New Battery
New water pump
New cam belt and cam idlers
New rocker cover gaskets
New hex bolts for rocker cover
Heater pipes
(pipes from hell) bypassed with hoses under fuel tank
Lowered suspension 30mm
New Blueflame system
New down pipe
(the one with flexy bit)
New 7mm coil pack
Original Toyota 7mm plug leads and plugs
New toyo's on the rear
New rubber flexy brake hose's all round
Calipers cleaned and serviced with new seal's fitted all round
New brake disk's grooved and galvanized all round from CRN
New brake pads all round
New hand brake cables
New anti-squeel shims
She's drives really well as well
Don't know what I'm going to do!
Before I found out that it was this bad under the sill's a chap quoted around
£700 to weld supplied sill's on, god knows how much he would charge for cutting this sort of corrosion out and fabricating new panels to repair the inner sill as well! it's just as well I had a dig around myself.
Oh, what do you chap's think?
Trev
