Anyway, both cams lined up to the backing plate markers fine.
So either there both out by a tooth or 2 or the timings ok.
Well yes, as I say there either fine to each other, or both out(which would obviously suggest crank jumped)
jimGTS wrote:Dale isnt that what i'm saying???
If the cams line up different, cam jumped
if cams line up the same, crank jumped
confused.
Anyway, both cams lined up to the backing plate markers fine.![]()
Dale_V wrote:
when i first read the topic, my initial thought was a fueling issue
Dale_V wrote:thats what I mean, all was ok until you fitted a rev3 rail and rev3 injectors
this isnt on the same scale by any means, but on my old NA engine the engine would tick over fine, but ANY revs and it cut out..
start it back up and it idled, rev
> died again.
the issue was lack of fuel!
where did you get the rail and injectors? are they known to be good items? are you 100% positive the wiring you re-did is spot on?.
Do the cambelt timing first, but if that is fine I would be tempted to pull the inlet manifold off and fit your 850's.
jimGTS wrote:Dale_V wrote:thats what I mean, all was ok until you fitted a rev3 rail and rev3 injectors
> died again.
the car can also have lack of fuel through bad timing tho correct??
i got the rail and injectors off here.
someone was going to use them on a rev3 ecu conversion.they looked ok to me, resistance on them was spot on.
but i will say this dale, i had the same symtoms before the timing was sorted..and that was with my 850s.
.same fine idle
(missing when revved hard, light throttle
= revved ok), so what are chances my 850s AND new 540s are dead.
i checked continuity of injectors to ecu and resistor pack and all checks out.
my rewiring is fine, you can see in the 2nd pic of page 1, these were soldered.
Dale_V wrote:im stumped, report back when timing is checked
jimGTS wrote:Dale_V wrote:im stumped, report back when timing is checked
exactly, why you think its been a nightmare, lol..
ill check tdc when i can.
managed to get an offer for help with the cambelt side of things if it turns out i do need to do a cambelt change, so thats good.
