Running car on bioethanol? mr2 turbo?
willfinch36
Post by willfinch36 »
50% super unleaded
50% biotehanol....
opinions?
Marf
Re: Running car on bioethanol? mr2 turbo?
Post by Marf »
Bioethanol requires lots more injector capacity than straight petrol, something to consider.
RobCrezz
Post by RobCrezz »
Marf wrote:Bioethanol requires lots more injector capacity than straight petrol, something to consider.
Yeah, very high octane, but lower amount of energy than petrol, so you have to use more of it!
Marf
Post by Marf »
Lots of information on converting is available on the American forum :thumleft:
http://mr2oc.com/index.php
rameairo
Post by rameairo »
Bioethanol has about 33% less energy so you need to made everything bigger... Look my garage and you see what it needs to get work well...
willfinch36
just my mate runs his mr2 turbo on it and says it makes a big difference?
and thats only got exhaust/de-cat/uprated clutch, lightend flywheel + charge cooler?
TubbyTwo
Post by TubbyTwo »
possible as an octane booster yes, but not sure about large quantaties.
was under the impression that methanol eats into alloy tho. iirc the MR2 has an alloy head?
2003 Leon Cupra R, stage 2 Jabbasport remap to 280bhp
MR2 now sold :(
willfinch36
he was running 20L v power + 20L of this other bio ethanol.. hmm
Marf
Post by Marf »
He should be careful about slinging bioethanol in his tank, it will alter the AFR and may cause rubber components in the fuel system to wear out prematurely.
willfinch36
so how much would you say is safe to use?
or not at all?
Marf
Post by Marf »
Without a way of monitoring AFRs I wouldnt like to say.
As far as I am aware petrol that contains bioethanol over here, tesco 99 is the only one off the top of my head, only contains 5% bio.
willfinch36
yeah. i 9 out of 10 put in tesco 99 rather than v power.
