Was cleaning my car when I noticed this behind the front bumper:
and also this
Is that the engine radiator or the aircon condensor? Will it affect my engine cooling?
Also, is that bent bar anything major?
Thanks.
Peterwolf wrote:Is the engine radiator.Change it or repair.
Mr Two wrote:Defo air-con rad
sw20GTS wrote:Should I go to Kwik Fit to try to have my aircon recharged? The A/C is not cold at all atm..
I heard that I might snap the belt the A/C motor is connected to is the A/C is leaking and motor seizes etc.
jmachling Posted: Fri Aug 28, 2009 9:22 am![]()
Post subject:
If you want to get it regassed, take it to an independent specialist as it'll be much cheaper.Make sure they pressure test it before regassing too or you'll be wasting your time
(and money).
It should really be pressure tested with nitrogen NOT compressed air- compressed air contains moisture that could cause problems in the system if it condenses if all of it isn't vacuumed out prior to refilling.
sw20GTS wrote:Hmm, I was roughly quoted 120-180 quid to get it checked and re-gassed.Might try other garage then.
sw20GTS wrote:Just to make sure though, I can still operate the normal fan(without the A/C or Econ switched on) and also the heater still works?
sw20GTS wrote:edit: Or anyone near Dundee area could recommend me a proper MR2 specialist that deals with this? The garage I went to actually had no idea how to remove the black shroud covering in the front.
Peter C wrote:sw20GTS wrote:Hmm, I was roughly quoted 120-180 quid to get it checked and re-gassed.Might try other garage then.
I had my installation pressure checked, de-pressurised, cleaned and re-gassed for£40, but that was in Poland, which might be a bit far for you to travel.
Correct.
The taps for the A/C are located beneath the plastic shroud, to the right of the spare wheel, which comes off by removing a couple of plastic clips- anyone can do it.
A/C connections are standard, no need for MR2 specialists to get involved.
HTH
