Hi all,
I've tried searching the forum for related topics but no joy. So here i go...
I have a TOAD powerkey which was installed back in 2002. Now Im having problems with it.
Usually, i have to wave the plastic keyring (i think its called a transponder tag) infront of 2 sensors located on the dash and this will disarm the immobilizer. For some reason, it doesn't switch off anymore. The car was parked up with battery disconnected for some time. I recently reconnected the battery and now the immobilizer doesnt turn off.
I'm not sure what i've done. I have a spare tag but this doesnt work either.
Any ideas???
[Mk2] [Turbo] TOAD Powerkey
Re: [Mk2] [Turbo] TOAD Powerkey
The alarm might have to store the tags ID and its lost it due to being without power for so long. You might have to re-program them just a guess.
Do you have a model number? do a search on google?
Hmmmm.. thats sounds right... No model no. though. I found the certificate but the idiots didnt write the product code. Only Toad Powerkey with the Thatcham evaluation number....
I'll google it now and see if i get anywhere but thanks anyways..
OKI wrote:Hmmmm.. thats sounds right... No model no. though. I found the certificate but the idiots didnt write the product code. Only Toad Powerkey with the Thatcham evaluation number....
It is a Toad Powerkey that is the model number now superceded by the Sterling excel
if no tags work its removal im afraid
Ian
I thought as much Ian. I tried to google a wiring diagram to get an idea of how to remove it but no joy.
I removed the dash under the steering column and found the alarm. Its has so many wires and they are all black. Grrrrrr
I traced most of the wires and they seem fairly easy to remove but some are a bit iffy.
I will try to remove it in a few days. Any advice Mr Toad Installer??
MR_TOAD_INSTALLER wrote:OKI wrote:Hmmmm.. thats sounds right... No model no. though. I found the certificate but the idiots didnt write the product code. Only Toad Powerkey with the Thatcham evaluation number....
Ian
sorry for the thread hijack ,
i recently bought a Toad Ai606 with two key fobs but i didn't get the 4 digit code, now i can't use the alarm until i can find some way of extracting this code from the unit...
any ideas or anywhere i can send the unit to get the code reset or how i am able to do it myself...
cheers
and sorry
Ring me on 07774 446402 and i will answer all questions
Cheers Ian
Cheers Ian
MR_TOAD_INSTALLER wrote:Ring me on 07774 446402 and i will answer all questions
Cheers Ian
thanks
Cheers Ian
Ian,
I followed all the wires from the alarm unit and most are easy enough to remove. But some are confusing the hell out of me!!
In theory the alarms wires should connect to the cars loom right?? In some cases by attaching to a wire and in other cases bypassing a wire. Thats my problem i found 4 or so black wires that look as though they are part of the cars loom and they connect in pairs to a single wire from the alarm. If i remove the alarm wire i will be left with 2 or more loose wires (from the cars loom) with no idea where to reconnect them.
Hope that makes sense
I would call you but i live in Cyprus and the bill will be crazy big. If i take some photos of my trouble spots and email them to you. Do you think you can help??
Sorted!!! I removed it....
The problem the wires that confused me came from another alarm I had (autowatch)... Removed them both with no problems at all.
Pretty easy to be honest.. only took a couple of hours..
Thanks for your help anyways Ian.
Ian,
Thanks for the PM and info. Came in very handy!!!
Dont know what i would have done without ya.
