Jimbob wrote:Its on a home brew boot mount.900x600x75mm by memory.
My full spec is in projects.
Cheers Marc, i'll pop over some time.How's yours now?
Jimbob wrote:Pity, last time I went in it I was scared!
If you take any bits off before you sell let me come pick up those lights of yours!
Kongaroo wrote:Nice power curve Jimbob![]()
I hope you don't mind me asking but why was your Inlet air Temperature(IT) so much higher than the Ambient Temperature
(AT)?
Normally there is only a few degrees between them but on yours there is a 29 degree difference?
Was the Inlet air sensor sitting in the exhaust stream?
The only reason I'm asking is I believe that if your'IT' is high then a Dyno Dynamics dyno will apply a higher positive correction factor to the power results?
Jimbob wrote:The runs were all done using the IAT in my inlet pipe which sits before the TB.On the last few runs the temp was creeping up so we fitted an additional sensor in.
I am pretty sure the runs are uncorrected though.We just fitted the additional sensor to verify temps.
The run previous did 498 before fitting it, and the temps dropped a bit for the final power run.
Dave said we could sit around for half an hour and probably get even more once things cooled down, but I was happy enough.
Jimbob wrote:No offence taken, I got your point though.
The run previous to this had no thermocouple installed on my car.That run made 498bhp from memory.
I am unsure where this correction factor comes from but its made 10bhp difference? Plus the car was actually cooler on the final run so would have been making more power anyway.
Dave and Mark where in charge of the dyno, I just watched an smiled.
Anyway, I can't get too excited about that.One becuase I don't know exactly how things are calulated, and two the car feels plenty fast enough.
