This MAY be a can of worms, but.
I don't go along with this
"you MUST stick with the 205/185, or otherwise the car will be very dangerous.
Basically, if you increase the width, you'll get more grip, BUT the profile, wheel width and of course the make of the tyre will surely have a greater effect on things than the tyre width alone.
I suppose the slightly wider rear tyre gives the rear slightly more grip than the fronts.
.but the lower profile will mean that when it lets go, it will let go more suddenly?
But what happens if you use the correct 205 rear tyre, but its a mid-range tyre: your handling
/balance will alter.
This is just the beginning: changing any of the variables will have an effect on the handling: also your driving style
/ ability has a huge bearing on whether you end up in a ditch or not, as do weather conditions, etc, etc.
Basically, its up to the individual: if you're a good driver, then I would suggest you can get away with, say,
17"/ 215's all round and you'll be fine.
Of course, when you lower
/ uprate the suspension, then things change further.
A can of worms, truly.
![Confused :?](./images/smilies/icon_confused.gif)
