You cant buy solvent based paints no more, its all water based, which is a bit of a pain in the ass cos the drying time is a lot longer, needs to be done in a proper heated booth, and you need a decent gun with a 1.3mm nose on it, not the crappy
£60 guns from halfords.
On a plus side though, you get a lovely finish with water base.
what you spraying anyway? if its only something small your beter off getting the colour made up in a rattle can, but personaly i wouldnt use halfords for that either.
