I thought vacuum leak somewhere, but I can't find anything.
Can smell fuel, so getting fuel, the car is firing on 4 cylinders an sounds perfectly normal, but just dies.
JJ wrote:Jim,
You've only had the exhaust manifold off??
Work backwards..
what exactly have you removed that will affect the electrics
Fromt he work you've been doing.
its all nuts and bolts
3S Service Centre wrote:Quick check! do you have a sealed vacume to the map sensor.
jimGTS wrote:Wiring diagrams are alien to me unfortunatly.
I can use a multimeter, but as for understanding those diagrams, LOL.
I did exactly what I did to my old rev2 regarding the spal fan and stock ic fan connector.Never had any problems on the old car doing that.
Lewis Jay wrote:jimGTS wrote:Wiring diagrams are alien to me unfortunatly.
As you say the wiring is different on the Rev 5 to the Rev 2 just because it worked on the Rev 2 doesn`t mean it will o.k on the Rev 5.
This is the only change you have made to the car`s wiring, you say, so I would rule that out first mate.
