Celica GT4 WRC 4 pot caliper conversion
Categories: MR2 Mk2 Articles -> Brakes
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=98]Knowledge Base - Celica GT4 WRC 4 pot caliper conversion[/url]
First things first, the calipers are NOT a bolt on fit, the spacing of the bolts is different, also GT4 discs will not fit as they have a 100mm PCD as opposed to a 114.3mm of the MR2.
I used discs from a Lexus LS400 which have the right bolt spacing, disc height and a diameter of 313mm, which is plenty! they were also reasonably priced from www.brakesint.com.
The biggest issue is bolting the caliper to the hub.
The strut mounting bolts are bolted straight into this bracket
As can be seen from the picture below the bracket is not that simple, with the strut holes not being planar with the hub face.
The lower mounting lug hole needed moving towards the centre of the axis by 6mm in order for the pad to sit correctly on the disc.
Please be aware that you should not cut lugs off either calliper or hub and re-weld as you do not know the correct specification of the material and therefore it isn't possible to be 100% confident that you are using the correct weld wire, plus assuming you are pulling 1G under braking then a quarter of the weight of the car may be going through each weld.
The caliper width forced me to space the wheels out 5mm, therefore I needed to use extende wheel studs, the old ones were pressed out and new one pressed in using a hydraulic ram.
The caliper mounted provisinally to the hub can be seen below:
Although the caliper has
The whole lot was offered up to the car, as you can see below the caliper is a substantial size!
The brake hose no longer reaches the caliper, at least not when you utilise the retaining bracket on the strut.
So there you have it, easy! All in cost was around
the pic below is the brakes on the car, I havent used it for a little while so the discs have gone rusty, although I assure you there brand new!
