Dead Battery Syndrome
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=74]Knowledge Base - Dead Battery Syndrome[/url]
I returned from a 2 week holiday to find the battery on my MR2 MK2 as dead as a dodo, oh fishhooks!
A new battery was fitted
I connected the positive lead to the battery, then joined the negative lead in series through a multimeter on the DC Amps range.
On reading IMOC Electrical I was supprised that I was unable to find what the base current should be, and many articles suggesting fancy batteries.
Pull the fuses, one at a time, and check the current draw, replace the fuse and move on to the next one.
I was stuck without a circuit diagram, this is where I found links from IMOC really useful.
The problem was a duff Alarm
Without the alarm the base current dropped to 0.02 amps
Fit new Alarm, job done
I trust this will be of some use to any
