Popup Headlights Mod
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=66]Knowledge Base - Popup Headlights Mod[/url]
The Headlight Mod
by Paul Walker
This modification will allow Mk2 owners to flash their headlights with their sidelights on without having to worry about the headlights staying popped up.
Tools and parts required
Step 1
Open the front bonnet and locate headlight control box, which is just below the fuse box on the right of the car.
Step 2
Coming out of the bottom of the blue box will be a plastic wire connector.
Step 3
Locate pin 6 on the connector.
Step 4
Fit the switch between the two cut ends of the red wire from pin 6 on the connector
Step 5
Plug the plastic connector back into the blue headlight control box
With the switch in one position, you should be able to flash your lights with the sidelights on, and the headlights will pop up and then go back down again.
The picture on the right shows the blue headlight control box and the white switch in place.
