[url=https://imoc.co.uk/app.php/kb/viewarticle?a=65]Knowledge Base - How to fix the pop-up headlight controller[/url]
Hello
Whilst trying to get my car ready for the Tatton show, I needed to get an MOT done, all was well apart from the headlights.
When I turned them on this happened.
Right up, pause, left up, ok not end of the world, then I turned the lights off.
Left down, pause, right down, pause, right up 1/2 way, down, up, down then up a little bit, poor car looked like it had been punched.
As I am into electrical/electronics stuff I thought I would have a go at fixing the problem.
After removing the headlight
"Retractor control" from next to the wiper motor I set about stripping it down.
First carefully lift up the 4 tabs fitted to the cover.
Now slide out the PCB.
First of all I removed the relay contact covers.
And then cleaned the contacts.
I then fixed
(re-soldered) any dry joints I found, there were a few.
And finally mended a broken pin on the connector.
The problem.
The fix.
Hopefully this will be helpful to anyone with a similar problem!
