Replacing 5th Gear
Categories: MR2 Mk1 Articles -> Engine
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=62]Knowledge Base - Replacing 5th Gear[/url]
Replacement of 5th gear, it’s needle bearing and the synchro ring.
These are the parts I bought, plus the shift fork and hub sleeve.
First jack rear of the car up, place securely on stands and drain the gear box oil
With a screwdriver and hammer tap the snap ring off the end of the shaft, it sits in a groove.
Fit a 3 inch 3 leg puller onto the end of the shaft and link the legs under the hub;
My puller didn’t have a cap on it so I placed a small 10mm
Wind the puller in slowly, don’t go too mental on it or again it’ll pop off.
Once the hub is off 5th gear, the synchro and the spacer ring will slide off easily.
A comparison of the old and new 5th gears:
Old and new synchro rings:
Reassembly:
Push the new spacer onto the shaft.
Lubricate the needle bearing with some gearbox oil and place inside 5th gear then slide onto the shaft.
Lubricate the synchro ring and fit onto 5th gear.
Clean up the teeth on the hub and the spline on the shaft.
Fit the hub to the end of the shaft with the thickest centre ring of the hub on the outside, if you look at the second picture you will see that it is actually higher than the toothed part of the hub.
With a 22-27mm 1/2inch drive socket and extension drive the hub onto the shaft, I used a 22mm deep impact socket and it was just big enough
Back over to Lauren's article to refit the hub sleeve and fork
