How to Fix Snapped Studs in Front Bumper Strips/Toblerones
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=51]Knowledge Base - How to Fix Snapped Studs in Front Bumper Strips/Toblerones[/url]
This is how I fixed my front bumper strips.
This what you're usually left with after you've had to remove the bumper for whatever reason:
1.M6 Helicoil thread repair kit
2.4 Stainless M6 bolts approx 25mm long
3.Loctite thread lock
Tools needed:
Junior hacksaw
File
Tap wrench/small adjustable
Electric drill
3mm Drill
Centre punch
Hammer
This is the sort of kit you'll need:
First off, protecting the finish on the bumper strip as best you can, cut off the remainder of the stud flush to the bottom of the bracket until you are left with this:
Using the hammer and centre punch put a mark in the centre of the remaining bit of stud, then drill out
With the hole drilled out 3mm, put in the drill bit from the helicoil kit and drill out the 3mm hole to the same depth as before.
With the hole drilled out, it is now ready for tapping.
You are then left with this:
Take an M6 insert from the kit and place the tang into the slot of the inserting tool like so:
Screw the insert into the tapped hole you have just made until the top of the insert is flush with the top of the hole:
You might be able to break the
With a bit of Loctite threadlock on the bottom of the M6 bolt, screw this into the threaded hole until it bottoms out and goes tight
Then cut off the head of the bolt leaving approx 15mm of thread.
Hope this helps and save some folk some money
