Oil and filter change 3S-GTE Rev 4
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=25]Knowledge Base - Oil and filter change 3S-GTE Rev 4[/url]
Regular oil and filter changes are the most important part of your car's maintenance schedule.
This job isn't rocket science but there are easy and less easy ways of changing the oil and filter to reduce mess.
Warm the engine to normal operating temperature, this will allow the oil to drain easier.
Unless you have access to a hydraulic ramp, jack up the rear of the car
It'll make your job a lot easier by removing the four 10mm bolts that hold the plastic undertray in place.
This is where the job can get messy, so place some old newspaper on the ground and use a flat bowl or oil catch tin placed under the sump.
Remove the oil filler cap on the engine side:
Have your preferred oil and filter ready:
Fill the new filter 2/3 full with new oil.
Adjust the position of the oil catch bowl and remove the old filter
Fill the engine with new oil.
You may find it useful to print off a few labels showing the date and mileage when the oil/filter were changed.
Fit the rear wheel and jack down the car.
