Full Alloy Wheel Refurbishment Guide
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=138]Knowledge Base - Full Alloy Wheel Refurbishment Guide[/url]
Before I start, I take no responsibility for any damage you cause to yourself, or you property by use of this guide.
I've tried to estimate the paint ammounts required, this has been estimated from my usage, using aerosol cans.
Etching Primer
Grey Primer
Paint
Laquer
Some polish/t-cut and polishing cloth
An electric detail sander with 60
Wet and dry paper 800-1000 grit
Unibond metal repair kit
A full refurb will take around 4 days in total, 2 days sanding 2 days painting.
To do a full refurb, you will need to remove the tyres from the wheels.
Take the wheels off the car and wash them down front and back with some decent wheel cleaner to remove all the brake dust and grime from them.
Take one set of slightly damaged wheels, not looking too hot.
The first stage is to remove any paint, this is important if your wheels have been previously refurbished improperly.
I've always used an electric detail sander to remove the paint as it gets into the corners easily and speeds up the job.
1) Sand the wheels with 60 grit paper followed by 120 grit paper.
2) If you've got kerb damage like I did, file or sand the damage down untill the lip is circular, then mix up some of the liquid metal and smeer plenty of it on to fill the damage.
When spraying, spray at a distance of 6inches and spray with a smooth motion and with light coats.
Lots of light coats is much better than 1 heavy coat.
Always spray the rear of the wheel first, as some paint will overspray onto the front.
3) Spray the entire wheel with a light coat of etching primer, untill you can't see any bare metal This is very important with alloy wheels.
4) Once the primer is properly dry rub it down
5) Clean the wheel off with a damp cloth and spray several coats of the colour of your choice.
6) Make sure the paint is dry, spray on several coat of laquer to finish it off.
7) Let the laquer dry overnight and tcut
Job done!!
