clutch bleeding the easy way...
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=128]Knowledge Base - clutch bleeding the easy way... [/url]
right.
just you and a friend.
right, here we go!
firstly, fill up the resavour
undo the union on the bulkhead to bring the fluid into the clutch line.
open bleed nipple on the slave cylinder and have a friend lower the clutch pedal slowly, close nipple and repeat.
when you start to see fluid coming out, close the bleed nipple and lift pedal.
pump pedal between bleeds to make sure your gaining pedal feel.
good luck
