Changing a rear bulb (rev3+)
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=127]Knowledge Base - Changing a rear bulb (rev3+)[/url]
Cross-headed screwdriver.
Flat knife or similar.
The replacement bulb
In case any of your old clips have become broken, here’s the part number.
The rear before we start.
My tool for removing the corner unit of the light.
Cover the flat tool with paper, thick tissue or similar to help protect the plastic of the corner unit and lights.
Now you will see 2 screws, remove these.
With the rear boot lid open, remove the final screw shown.
Carefully pull the light unit towards you.
Once the bulb is replaced, simply put everything back together in reverse order.
