Mk1 service schedules and information
Categories: MR2 Mk1 Articles
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=113]Knowledge Base - Mk1 service schedules and information[/url]
This record covers the Pre-Delivery Inspection
To keep your Toyota operating at optimum performance and economy, we recommend that you also regularly take advantage of the electronic disgnostic facilities available at all Toyota Dealers.
Over a period of time, the durability of certain items reduces.
These recommendations are additional to the maintenance items checked at the 48 months/40,000 mile service and as they are safety related items, we strongly advise that you consult your local Toyota Dealer who will be pleased to give you a quotation.
The correct grade of engine oil to be used in Toyota engines is as follows:
Petrol engines
In the interest of reliability, we recommend that your Dealer carries out pre- and post-winter check ensures vital items such as windscreen wipers, lights, tyres, brakes and engine cooling system are ready to see your Toyota are in the best condition to take you happily through the summer.
We also recommend that the underside of your vehicle is power washed at the end of each winter to prevent build-up of mud and guard against corrosion from salt and chemicals used on roads during winter.
Check engine coolant level and strength.
Inspect exhaust system and mountings for security and leakage.
Check drive belt deflection.
Check and clean spark plugs
Inspect battery electrolyte levels, and terminals for security.
Check brake and clutch fluid levels.
Check brake and clutch system pipes, hoses and connections.
Check transmission, differential and steering for oil leakage and report
Lubricate propeller shaft grease points
Check all lights for correct operation and alignment.
Check windscreen wipers/washers for correct operation/direction and top up washer fluid level.
Check tyre condition and inflation pressures.
Check seat belts for correct operation.
Ensure interior and exterior is free from grease and dirt.
Road test and report.
Check valve clearances
Inspect drive belts for wear and deflection
Replace engine oil filter.
Inspect cooling and heater system hoses and connections.
Inspect oil cooler hoses and connections
Replace spark plugs.
Inspect CB points and rotor, replace if necessary
Check ignition timing, dwell angle and advance operation.
Check battery electrolyte levels, and terminals for security.
Check engine idle speed, CO emission and choke opertation.
Inspect fuel tank cap, fuel lines and connections.
Inspect fuel vapour check valve.
Check throttle positioner
Inspect exhaust gas recirculation system
Check brake and clutch pedal free play and parking brake travel.
Check and report on brake pads, discs, linings and drums, clean out dust.
Check steering wheel free play and linkage for wear and tear and security, including front wheel tracking.
Inspect ball joints and dust covers.
Inspect drive shaft dust covers
Check differential oil
Check transmission oil
Check transfer box oil
Check steering box oil level and PAS fluid level
Lubricate propeller shaft grease joints
Inspect front and rear suspension for correct operation and security.
Check all electrical systems for correct operation.
Check tyre conditions, inflation pressures and report.
Inspect drive belts for wear and deflection.
Replace CB joints, inspect rotor
Check battery electrolyte levels and terminals for security.
Replace fuel filter.
Check engine idle speed, CO emissions and choke operation.
Check brake fluid vapour lock
Check clutch fluid level.
Check steering wheel free play and linkage for wear and tear and security including front wheel tracking.
Change differential oil
Change transmission oil
Change transfer box oil
Check tyre condition and inflation pressures and report.
