Sill & wheel arch repair
Categories: MR2 Mk1 Articles -> Exterior
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=112]Knowledge Base - Sill & wheel arch repair[/url]
Taken from Bill's post here
http://www.imoc.co.uk/forums/viewtopic.php?t=76681
I bought panels from Montmoss LTD Bolton
www.body-panels.co.uk The sills are off an escort mark 3-4
Sills no.
Off side
Rear wheel arches
near side no.
Off side no.
Delivery approx.
Tel: 01204 393506 Fax: 01204 522114
E-mail: [email protected]
Tools I have used
Angle Grinder.
This is the damaged section of the sill cut away, normally the top section of the sill is not rusty you will be welding the top of the sill to this section prepare by cleaning off all the paint off the top for the weld to take.
Use scaffold pole and clamps to increase the bend to approximately 90 degrees
This shows a small piece of the sill, as an example.
Section for repair at the bottom corner of the wheel arch
Inner and outer wing sections cleaned up ready for welding, you can see the new sill section in the bottom right hand corner that is welded in place.
This is the inner wing shaped and welded to the angle iron
make and weld a new outer section to the outer body, shaped and welded to the angle iron
A few views of the inner section repair that was made using a piece of the angle iron
Note: this is it welded to the nearside wing.
Datsun Cherry Wheel Arch, this is the offside arch, I bought this from montmoss LTD
This is the wing cut out from just below the radius and slotted to allow the radius to mate with the MR2 inner wing and keep slotting as needed also the bottom left hand corner has to be cut to shape.
Cut and follow the chalk line to remove the excess so it tucks into the wing
Grind and Polish up the wheel arch ready for welding the new section when glued in place on the bottom radius
Apply plenty of liquid metal glue
Clamp the wing at the top with long nose pliers and tack every
This is how it should look when it is welded this is the near side
All the welds ground down ready for filling
use filler to make the radius and smooth the body line
This is the finished wing ready for painting after filling
Wing masked off and sprayed
Wing t-cut and polished sill, sprayed with underseal and ready for fitting the spoilers
I did this work in may 2006 and have been trying to get it to load since!
the only thing you get in a hurry is babys.
ps thanks to paul woods for all his advice and help on the work I did.
