Headlight bowl removal / replacement
Categories: MR2 Mk1 Articles -> Exterior
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=110]Knowledge Base - Headlight bowl removal / replacement[/url]
NB This is not best practice for changing a headlight bulb
After an incident with a gritter lorry left me with this
I had to
First of all, you'll need to get the headlights into the locked up postition.
Now remove the black plastic shroud around the headlight.
The bowl itself is held in place by 2 adjustment screws
Now you have to remove the power supply to the bulb.
Now you've got the bowl off the car, you can replace it for one without a smashed lens.
Good luck.
