Sagging Door Fix
Categories: MR2 Mk1 Articles -> Exterior
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=109]Knowledge Base - Sagging Door Fix[/url]
Many of you may experience the
The aim of this KB article is to raise the bottom of the door ever so slightly so that the striker and catch line up once again, making for a perfect close once again!
Firstly remove one of the 12mm bolts on the bottom hinge bracket on the door side
Next track down a couple of matching washers that will fit that bolt you just removed!
Undo the remaining bolt a couple of mm so that you can lift the door off its hinge and slide a washer behind the empty bolt hole bracket.
Replace the first bolt and tighten, this is to ensure you do not move the door out of alignment
Remove the second bolt, and repeat the above steps.
The first time you attempt to close the door,
The original suggestion for this fix is from Karl_T as found on the Mk1 Club Site so the original idea goes to him, I just typed up different instructions!
