T-Bar eccentric rod guide installation
[url=https://imoc.co.uk/app.php/kb/viewarticle?a=38]Knowledge Base - T-Bar eccentric rod guide installation[/url]
Introduction\
The position and fit of the T-Tops in the Mk.2 MR2 can be adjusted by replacing the two small plastic rod guides in the locking mechanism with a similar part manufactured with the hole off-center.
Eccentric T-Top rod guidePhoto 1M4 x 10mm machine screwsPhoto 2
At this point, I re-attached the locking handle
Reassembly, as the books say, is the reverse of removal.
