cheers, neil.
kaiowas wrote:I'd guess it depends on what you're planning to do with regards engine management.![]()
cartledge_uk wrote:
The uk club members are so conservitive
crazybrightman wrote:oh another thing im guessing the gze has oil squirters for the pistons and the n/a does not?
crazybrightman wrote:as for the ecu side of thing am i right in think the charger setup will only run one bar boost before fuel cut? can the gze ecu be remapped and a 3bar map sensor be fitted to up this range?
crazybrightman wrote:im aiming for mid to high 200's just so im not rebuilding the thing every 2 minutes and as im not sure how the transmissions going to cope past that.![]()
crazybrightman wrote:i just want to keep the little light and rev hapy 1600 rather than sticking a bigger lump into the car.
crazybrightman wrote:im thinking use my current engine from my 1b(a large port im guessing?)
go with some forged rods and pistons, rebuild everything else to as new and stick some aftermarket ecu on it running sensible boost should see my target no probs with a decent turbo.
so then comes the problem of the transmission, the best paddle clutch ive seen so far is only rated to 260ft'lb which is going to be on its limits so not the best choice.then the gearbox and driveshafts what upgrades are avaliable from other models?
cartledge_uk wrote:crazybrightman wrote:oh another thing im guessing the gze has oil squirters for the pistons and the n/a does not?
no
The 1st gen 4agze(AFM) is the same as the 2nd gen 4age internals
The 2nd gen 4agze is the same as the 3rd gen 4age internals(small port and oil squirters)
The 3rd gen 4agze is the same as the silvertop 20v bottom end, small port head.![]()
(oil squirters, etc, best engine to own)
nope,
The early charger set up is AFM, so boost as much as you want
, the later set up
(gen2 4agze onwards
, with the oil squiters) is map sensor and fuel cuts at 14.7psi
(I don't know this for definite, just from reading, but quite plausable)
The N/a box eats itself at 250bhp
The best way![]()
Yes.If you see what people do in Australia and America it's quite amazing how much power you can get out of these little engines
PW@Woodsport wrote:Yes.If you see what people do in Australia and America it's quite amazing how much power you can get out of these little engines
.before they go bang.
Yet to hear or see any that lasted any significant length of time,reliability is a major factor with a tuned engine like this.It really isnt a simple or cheap thing to do,you will be looking at thousands of£££ to build something that will not only support 250bhp but also stay that way.
PW@Woodsport wrote:
There are easier,cheaper and more reliable ways without adding too much weight.
greglebon wrote:I've gotta side with Paul, here..
Tuning a 4A to 250-300hp is right at the top end of its engineering window: the Atlantics run 250, but get rebuilt after each race..
You'll need every component to be in tip-top condition, balanced, etc..
