[All] [Generic] redex anybody still use it
fearless
Post by fearless »
as title says anybody still use redex i came across some in my shed the other day and decided to put some in my 2 which i did, next day drove to work gave it a bit of welly and see black crap comming out of the back car went like a rocket though, when i got to work i gave car a rev still a little black smoke comming out but 2 days on car is all clear and still going like a rocket, now was it the redex that done it or just maybe had a blockage and it cleared well happy car pulls like a train in 3rd :thumleft: :thumleft: :thumleft:
Tiny
Re: [All] [Generic] redex anybody still use it
Post by Tiny »
Its good stuff how old was the Redex? They changed it a few years back as it wasnt "environmentally friendly" and changed the mixture which basically made it not as good.
fearless
Post by fearless »
hmm that might be why it was good stuff had it in there a few years loads of cans and bits that get pushed to the back you know how it is :thumleft: :thumleft: :thumleft:
Tiny
Post by Tiny »
did you do it through the plug holes or just add a xxxx load to a tankfull?
fearless
Post by fearless »
i did both thought might aswell i remember the good old days of carbs spraying carb cleaner down them and watching all the crap come out ,times i used to do that when i was into old escorts rebuilding carbs out of old ones :thumleft: :thumleft: :thumleft:
dawolf
Post by dawolf »
Redex used to be all the rage. I once used some in my RS turbo and it seemed to respond better afterwards but could've just been my imagination. I'm not convinced it makes that much difference really but then again some mechanics reckon it's really good stuff. I still have a bit left in my garage somewhere.
Tiamat
Post by Tiamat »
I use it on ym motorbike but thats all. I tend to use 10K Boost on the MR2 - that works a treat. Though 2mins at a time at 2.5K revs doesn't please the neighbours with my exhaust!
fearless
Post by fearless »
something defo happened in my case as for what i dont know, but defo quicker praps in a few thousand miles i will give it a go again see what happens :thumleft: :thumleft: :thumleft:
RST
Post by RST »
I swear by it, just the recommended dose every couple of thousand miles -in the tank according to the destructions on the bottle.
Doesn't make a huge difference but enough for me to notice if it hasn't been used for a while.
Steve-O 2007
Post by Steve-O 2007 »
Can this be used on a turbo or just NA ??
fearless
Post by fearless »
i think its ok for all engines as its a cleaner will check on bottle for you sure i used it on my turbo's ive owned fiesta, and escort :thumleft: :thumleft: :thumleft:
JeffD
Post by JeffD »
Spittinflames
Post by Spittinflames »
Redex is good stuff, I still use it today.
Used to tip it down the plug holes on some of my older cars, smoked like a bu88er for ages though... but its all good fun.
I swear it makes your car feel quicker, the only product that actually does.
JeffD
Post by JeffD »
Went out and bougt some last night - went for the full system cleaner.
http://www.halfords.com/webapp/wcs/stor ... ryrn_58758
No smoke out the back but car seemed to pull a little bit better - most probably my imagination though! LOL
Steve-O 2007
Ill have to get some now then :mrgreen:
Spittinflames
JeffD wrote:Went out and bougt some last night - went for the full system cleaner.
You wont get smoke unless you tip it down your plug holes, Mixing it with fuel shouldnt create any smoke.
MrGazz2
Post by MrGazz2 »
Do you mean to say you take out the ignition leads and spark plugs and then put it directly into the engine that way as well as in the fuel tank?
Only ever used it in the fuel tank, putting it directly into the engine through the spark plug holes sounds really dodgy to me... but if its designed for that then so be it.
JeffD
Post by JeffD »
The instructions on the stuff I bought said add the whole bottle to a near empty tank then fill up.
Ive added redex directly down spark plug holes years ago but that was to my old Triumph Spifire - never done it to a two.
Tiny
Post by Tiny »
I wouldnt put their full fuel system cleaner directly into the bores only the genuine original stuff that looks like red syrup its mildly aciic so it will remove the deposits/crap that build up on the valves and on the top of the pistons
jimGTS
Post by jimGTS »
could just take the head off instead and clean the piston tops :eye: \:D/
before
after
