hello
does anyone runs his car on it ??
is it hard to wire up ?? i mean the speed/revs connections.......
cheers
[Mk2] [Turbo] HKS EVC 6 anyone ??
Re: [Mk2] [Turbo] HKS EVC 6 anyone ??
I have one, but I haven't put it on the car yet!!
Doesn't look too hard at all, power, earth and the 2 connections you've mentioned.
There's a choice I think, you can have speed and either revs or injector duty. Either way it'll just be a case of patching into the ECU harness. You have to patch the wires in though, not cut them!!
very very easy, i used the rev and throttle input as it makes boost control better than using a speed input.
cheers karam
cheers karam
ok can someone tell me then where to look 4 the rev and TB "cables" look 4 ?? where is the easiest place to connect to them ??
thanks
thanks
I don't know the colours of the wires yet but the best place to patch into them would be at the ECU (which is in the boot, behind the carpet incase you don't know) where the plugs go into it.
thats what i thought but need the colors and positions of the pins
Slarty wrote:I don't know the colours of the wires yet but the best place to patch into them would be at the ECU (which is in the boot, behind the carpet incase you don't know) where the plugs go into it.
anyone ?? which one is what on the ECU plug ??
cheeeeeeers a lot
