Tried everything today including the big hammer approach as suggested on other threads..is the only option a professional press? or will heating help? what is safe - could a blow torch burn away bearing grease? anything else i can use?
cheers all.
[Mk2] [Generic] Cannot remove wheel studs from hubs
Re: [Mk2] [Generic] Cannot remove wheel studs from hubs
I did all my rears this weekend, just gave them a good solid hit with a lump hammer and they popped right out,
A lump hammer will suffice, what hammer you using a 2lb?
I know when mine were done we just used a big hammer and they popped out fast enough lol
you could try heating them up but like said you really have to hit them as thay are on a spline
+1 for the lump hammer, works everytime
put on socket and wrench if its a cheap one try a lever..then get a lump of scaffold pole ( great piece of kit)about 2 to 6 ft long slide it over your soket /lever handle and gently put your weight on .it produces enough leverage to lift a small house job done spray first with wd 40
peterc wrote:put on socket and wrench if its a cheap one try a lever..then get a lump of scaffold pole ( great piece of kit)about 2 to 6 ft long slide it over your soket /lever handle and gently put your weight on .it produces enough leverage to lift a small house job done spray first with wd 40
its not a twist force you need it's a straight on punch it out the back force you need. Sorry if I've misread your instructions...
- IMOC Affiliated Company
Often putting a wheel nut on nearly all the way and smacking that helps. Maybe use a spare incase you damage the threads.
allan welsh wrote:peterc wrote:put on socket and wrench if its a cheap one try a lever..then get a lump of scaffold pole ( great piece of kit)about 2 to 6 ft long slide it over your soket /lever handle and gently put your weight on .it produces enough leverage to lift a small house job done spray first with wd 40
+1 Its a square on whack it needs twisting wont do anything there 100% splined and interferance fit
I had to use a Limeymk1 to get my wheel nuts replaced.
Spray shed loads of WD40 on them and then use a Heat gun on the hub, give them a decent whack and they should come loose. (although I don't think we used the heat in the end as Chris was against it)
we found that we had to use a wheel nut to manage to pull them back in again, we just cut the head off of a ring spanner to give us that extra bit of lenght. I'll see if I still have it and can post it up to you if you want and then used a jack handle against the floor to stop the wheel turning and a braker bar to tighten the nut. (You can only do 1 at a time like this otherwise you have nothing to hold the wheel in place with the brakes off)
HTH a lil bit
Stuart
HTH a lil bit
Stuart
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
thanks all for input. am having another go on saturday with my father-in-law using advice given.
thanks loads stuart for offer, will let you know how we get on on saturday, my father-in-law is a machinist and claims he will be able to make anything necessary! that remains to be seen..!
2 jaw puller, the lump hammer approach won't do your wheel bearings any favours.
all done yesterday. spent an hour using an elaborate home made clamp to get the FR LH studs out then just hit the FR RH with a copper hammer instead. as everyone has said, popped right out after max of 4 hits.
i obviously wasn't using a good enough hammer first time round (£3 wilko's claw hammer!).
if anyone else tries this, i can't agree enough with how vital it is to file off some of the frets on the new studs if they are the same as the ones i bought. new studs were 5 thou larger diameter frets than the old and would have taken huge force to get in.
skinthespin wrote:the lump hammer approach won't do your wheel bearings any favours.
Yup... I used a ball-joint splitter on mine. Came out easy as 'owt..
I was thinking of the bearings and the hubs too..
