cheers
2bornot2b wrote:i wont know until the weekend but ive got a feeling my conecting rod bearing is knackered, can the work be carried out with the engine still in and sump removed?
cheers
Century Motorsport wrote:Before you take the conrods apart- number them all.
Its imperitive you put the rod caps back on in the EXACT way you took them off.
If you fit it 180 degrees out or on another rod you will know about it in approx 100miles.
Nathan
