[Mk2] [Turbo] cam cover change=poor runing
just changed the cam cover today and now the car hardy runs,any little bit of throttle and it wonts to stall,does anyone have any ideas what i could of done wrong all hoses and everything seems to be on?
Re: [Mk2] [Turbo] cam cover change=poor runing
sounds like you have an air leak, could be to do with the idle valve and your air flow meter. check all hoses and vacuum lines then check them again.
after all that reset your ecu and go for a spin.
cheers karam
cheers karam
i was going to say breather pipe not on properly or you could have a split in one which you may of made worse when taking off, go back on what you removed and check and refit
also check oil, lack of oil also make it run rough,
also oil filler cap aswell undo that and leave off it will run like a bag of xxxx
