It was brilliant for the first run i took it out with loads of power put after that when i take it out for a spin and drive it at high revs steam comes out the expansion tank so i turn it off and let the motor cool down, i have replaced the rad cap and stat.
![Brick wall ](*,)](./images/smilies/eusa_wall.gif)
The head has been skimmed and pressure tested so the ony thing we can think of is cracked block.
Im open to all ideas, thank you
