If it's fine when dry, not consuming oil and not overheating it's probably two different problems.
And neither is likely to be head gaskett.
Oil leak from the filler is either a blocked crank case breather, or just an old crappy oil seal.
The misfire when damp is probably ignition related.
Plugs
/ leads
/ rotor arm or dizzy cap.
