CHRISREV3YELLOW wrote:hi im currently finishing my rev3 project and just wondering if nebody has an idea wot sort of power it will make? the spec list is as follows.wossner forged pistons compression 8-1, hks hi power muffler, motoria downpipe, blitz panel filter, iridium grade 7 spark plugs, blitz dump valve, apexi power fc and commander wit boost controller kit, will be running 19 psi of boost on ct20 turbo, walbro 255lph fuel pump.
any ideas????????bhp sorry 4got 2 mension gredy intercooler kit
mattcambs wrote:CHRISREV3YELLOW wrote:hi im currently finishing my rev3 project and just wondering if nebody has an idea wot sort of power it will make? the spec list is as follows.wossner forged pistons compression 8-1, hks hi power muffler, motoria downpipe, blitz panel filter, iridium grade 7 spark plugs, blitz dump valve, apexi power fc and commander wit boost controller kit, will be running 19 psi of boost on ct20 turbo, walbro 255lph fuel pump.
I reckon in theory you should be able to hit 320- 330 fwbhp with a good map.
The limit is not the turbo as such, but the stock injectors.
As mrtee says, get your fuelling sorted
- i.e.
bigger injectors
- and a turbo upgrade
- hmm, let me think: GT30
- and you'll be able to make 400fwbhp easy
As you don't have a charge cooler, I would have thought an engine lid fan kit(Rogue) would be well worth it for the summer.
Skywalker wrote:is it really that mush quicker to write'wit' and
'wot' as opposed to
'with' and
'what'? It's one button lad!
CHRISREV3YELLOW wrote:does it realy bug you that much, you should try going out the house more it might help lmao
Antstarr wrote:WHy did u guys moan about his cooling? I thought Greddy is good for 400bhp?!
