Today I took the turbo inlet pipe off
![Brick wall ](*,)](./images/smilies/eusa_wall.gif)
![Think :-k](./images/smilies/eusa_think.gif)
Anyhoo.
When the gasket did blow again I was about 20 miles from home and I had a fair amount of smoke
Worried now that when I finally do get the turbo
Grrr
![blackeye :eye:](./images/smilies/icon_blackeye.gif)
Nick
mrtee wrote:could you not install a catch can and also put filters on the pipes joining the intake..
.or is that not advisable on a rev 2.
im not quite understanding why this could amount to piston ring failure though i have read this before..
the vent.pipes come from the areas that have oil flow so why would people presume ring land failure.
.i just don't get it
ring lands are the piston rings i presume![]()
FreeFall wrote:Well, I guess that the next step is to fashion up a temporary catch can and vent the outlet to atmosphere.If the catch can remains dry and the oil appears in the intake again, that points to turbo seals
- correct
Pleased it's not looking like a busted piston anyway![]()
Nick
2BAR Tuning wrote:Is this a t67 and motec m4
Yes the orginal map before its was tweaked by me was running very lean.
I just richened it up for safety and suggested getting a new link g3 or motec which was more sorted for the car IMO
Ryan
DNOS808 wrote:Hi
I really feel for you.I know that sinking feeling when you realise that some thing major may be up with the engine.
My mr2 turbo seems to produce alot of smoke from the exhaust so I may well have some big problems to deal with.
Hopefully it is only a turbo problem and not a blown engine.
bri0905 wrote:Why can't owens take it off and overhaul it for you? They are turbo specialists aren't they?
Bri
GhostWKD wrote:if its burning oil keep an eye on that oil level, last thing you want is to run it with little/no oil in there
