4 junctions up the m1 and my mr1 mk1 eating al least
1/3 a tank of fuel, it seems to be just eating fuel.
and thats taking it quite steady.
I seem to get 176miles out of a full tank
is this about right, what does every1 else get?
SuperRedMR2 wrote:mine is drinking fuel because my manifold to downpipe is leaking really badly.
before that i managed 230miles on 30 quid
Tonester wrote:well i get about 200ish to my full tank(about 35 quids worth)
but theres suposibly 43 liters to the tank..
.or so ive heard so
and i drive pretty conservative, normally change gears at 4k revs traffic dependant:O
so 30mpg aint bad for a 22 year old car.
feral4mr2 wrote:check your 02 sensor(if your guy's had them?), if thats faulty or not working the car will run rich.
plus many other variables or course which may add to heavy fuel useage.
feral4mr2 wrote:^^^
well there you go.
could be other things, cold start injector leaking, cold start injector timer doobie not working right.![]()
timing, dragging brakes like mentioned, wind resistence more than the day before.
BIGBOBO wrote:Tonester wrote:well i get about 200ish to my full tank(about 35 quids worth)
.or so ive heard so
You think that's conservative? I shift even before 3k most of the time.The Owner's manual lists the minimum speed you
"should" ever do in gears and I never go lower than that.
It is pretty low though, 50ish kmh for 4th gear
(30mph).
No point in wasting fuel when you're stuck in traffic or the city
I get around 400km out of a full tank(250 miles).
But I try to never take it out in rush hour.
I could probably get 450 if I behave a bit but that's not fun.
