basic story is, map sensor converted rev2 jdm engine to run a rev3 power fc.
anyway, i had it road mapped, it was showing high water temps, but not overheating.
week or 2 later, started overheating on high boost.
replace headgasket, 1mm cometic, and arps studs, and fit a gen3 inlet camshaft while the head is off.
now i get it back on the dyno to tweek the map for the gen3 inlet cam, and Ryan couldnt advance timing enough, and there seemed to be no air getting to the engine to mix with fuel, something along those lines Ryan tried to expalin to me.
possible cam timing, igntion timing wrong was a suggestion.
Went up to see Marc
anyway, ive also noted that aparently the powerFC controls this ignition anyway, so it doesnt really matter if my car was at 0 or 10, it still would have timed up correctly.
so timing it back up to 14bdtc, prob wont make much difference, but im not sure on this aspect of things??
any suggestions on what else could be causing this low level of duty cycle???
thanks
here are dyno graphs anyway, these are dyno dymanics UK dynos.
note 279hp is at the fly, 235whp at the wheels, 1.1bar, ct20b, 540s, power FC.
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/cams/100_1932.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/cams/100_1933.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/cams/100_1934.jpg)
